跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
Touch ID not working but said it does.
So, odd phenomena here. The home button is fully functional. The fingerprint scanner worked fine until recently. I highly doubt it’s a hardware issue. The Touch ID sensor can be “used” it lets you try and add a fingerprint/unlock with fingerprint, but doesn’t register when placed. Phone was updated, hard reset several times, Touch ID was turned off reset then turned on. Still no luck. Tells you to place finger nothing happens. If it had the “unable to activate Touch ID” then I would know it’s broken, but it doesn’t say that. It will let you go through the process but not register. The next logical step would be to do a full wipe. But was looking to see if anyone had any bright ideas before I do so.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Probably the MESA Boost voltage failed, therefore the logical part of the Touch ID chip is working, communication is working but it can’t sense any fingerprint contacts, which explains the silent failure rather than saying “Unable to activate TouchID”.
这个答案有帮助吗?
得分 1
1条评论:
Never met a board repair specialist who would repair that, too much work even for them. Plus the backlight is fine, wouldn’t that affect the backlight as well? Still I’m not quite sure.
完成的
添加一条评论
添加你的答案
Avais Gilani 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 62
