跳转到主内容
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
563 个问题 查看全部
Bent display lid from fall
Hi everyone
I just dropped my brand new MacBook Pro. The display lid is bent in the corner! :(
How can I fix this any ideas?
I already tried this but it didnt work :( Macbook Hinge Scraping / Scratching Problem - Quick and Easy Fix!
Thanks everyone.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
6个答案
最有帮助的答案
you don't want to risk that lcd for just trying to unbend.
这个答案有帮助吗?
得分 1
3条评论:
Actually youre right i dont want. But if is there any quick solution i would give it shot. Im glad screen work perfectly except that light.
完成的
The light in the corner is caused by the compression of the LCD panels as the liquid crystal material is being squeezed.
完成的
Can use like this or should i change panel immediately?
完成的
添加一条评论
Many a sin can be covered over using a good protective case. I really like these:
https://www.ebay.com/itm/Rubberized-Hard...
If you just can’t stand it, you can get one from PowerBook Medic for $650
http://www.powerbookmedic.com/MacBook-Pr...
I will be listing this part (a working pull) on eBay tomorrow for just under $500.
Pricey isn’t it!
这个答案有帮助吗?
得分 1
1条评论:
I ordered one protective case. I hope it will fit to my bended screen.
Thanks.
完成的
添加一条评论
The problem you face here is any reshaping of the lid frame puts the screen at risk of damage. The only solution is to replace the lid assembly which is quite expensive!
Sorry ;-{
这个答案有帮助吗?
得分 0
4条评论:
完成的
I would live with it
完成的
Ill do the same. Thank you.
完成的
Did the yellow discoloring worsen over time?? I dropped mine today and have the EXACT same issue :( fixing it will cost the same amount i bought my laptop for and wanna know if i can leave it how it is without it getting completely messed up.
完成的
添加一条评论
@fredy12 Did you got repaired ? because I am having the same issue
这个答案有帮助吗?
得分 0
添加一条评论
Accidentally hit the top left of my laptop screen onto a chair. Bent but no damage to screen. Only the screen has bright spots. ;(
这个答案有帮助吗?
得分 0
添加一条评论
I have this problem right now with my MacBook air m1. Did you ever get it repaired/ did it end up causing further problems?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ferdi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 27
总计 4,753
