跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2689 个问题 查看全部
Can’t answer incoming calls
Have a weird one have an iPhone 6s works great but when a call comes in screen stops working can’t answer and phone will continue to ring until I do a hard reset. I have taken it apart and cleaned it no water damage have replaced the screen install a new battery.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
Fix for iPhone keeps ringing but screen freezes: I know this is an old thread, but maybe it will help someone else. This happened on my Mom‘s iPhone 6. It started after I enabled Announce Calls for “Always” for her (under Settings/Phone). I turned off Announce Calls and the problem was fixed. The feature works on my iPhone 8 so it also could be a software update issue.
这个答案有帮助吗?
得分 2
3条评论:
The person that post about the announcing calls. Thank you soooo much my phone as driven me crazy but you helped fix it. I had tried everything. I turned off the announce calls and the phone is working again.
完成的
Tried this, no luck. Yikes!
完成的
I tried this, and it worked!!!!
Before the I phone 6 was ringing and I could not answer calls and front screen would freeze. only way out of it was turning phone off then on again .
Also on outgoing calls I could only call out once before locking. would have to turn phone off then on again.
Text messaging worked the whole time
完成的
添加一条评论
I would check and make sure there is not a software update that is missing. Sounds like a software issue. Go to setting ->General->Software Update and See if it shows and update that is needed. Best of luck.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Patrick Dean Willard 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 4,832
