跳转到主内容
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
465 个问题 查看全部
Backlight of the display isnt working, can I test a 13" display?
Hello, the backlight of my display stopped working.
I want to know if the display or the board is broken.
I have a a1502 from a friend, can i test the 13” display on my a1398 ?
Both are from 2014.
Kind Regards :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I’m sorry you received a wrong answer and hope you haven’t burned out your friend’s screen too. Retina screens don’t have any inverter, as a matter of fact neither the previous generation used inverter based technology that was last abandoned by Apple with the latest A1181 manufactured in 2009.
Even when connectors look the same, they might have a completely different pinout and suggesting to test freely different size screens without a previous pinout check I find it pretty asinine.
Try to put back in place the A1502 screen to the 13” to make sure it’s still working, if not either it got burned by a different pinout setting or by a possible short present on the 15” backlight circuit, but cross my fingers.
As far as your backlight is concerned, you’ll likely need the help of a real technician who could do some basic testing before plugging in a screen worth several hundreds to “see if it works”
这个答案有帮助吗?
得分 2
3条评论:
Wow, that could have end bad. Luckily it is still working. Thanks for your answer!
完成的
@kiwi12 Glad it's still working :) I'm always puzzled by the carelessness some people show giving advice on things they don't have a clue about, but the guy was not the first and I'm afraid won't be the last we have seen around doing that. If you can find a good technician in your area it might be only a matter of the backlight circuit rework, it shouldn't be much too expensive either.
完成的
You are very lucky, Good catch! @arbaman
MacBook Pro's use either an LED driver or Buck converter depending on the series.
完成的
添加一条评论
添加你的答案
M PI 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 126
