跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
iPhone 3GS bricked ;(
I went to go jailbreak and unlock my iPhone 3GS and I checked the box beside iPad baseband and told me that i can’t restore with stock ipsw, and I was ok with that so i clicked ok and it popped up with the iPad baseband is not compatible with iPhone units manufactured week 35 of 2011 or later. if this is an iPhone and if digits 3-5 of its serial number are "135" or later (xx135...), then you should NOT proceed! and mine was 145 and i proceeded anyways like an idiot and at the end the WI-FI tab said no WI-FI, and their was no Bluetooth, and no IMEI, no ICCID, and no Modem Firmware. please help, i cant find out how to fix it. PLeASE HeLP!!!???
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Your description says your IMEI is xx145xxxxxxxxxx (which is good). I assume you read the iPhoneHacks article. It says there that if your IMEI is xx135xxxxxxxxxx, you should not install the iPad baseband. But in this case, the iPad baseband's side effect may be remediated.
The latest redsn0w application (version 0.9.15 beta 3) gives you an option to downgrade from iPad baseband under the Jailbreak section. Assuming you currently have iPad baseband installed (06.15.00), you should tick the box "Downgrade from iPad baseband" then proceed with the normal jailbreak operation (Uncheck everything but Downgrade). If it gives an error, go to Extras then select "Browse" and point the file to a stock IPSW. Redo the steps above and this will fix your baseband issue.
If the first solution didn't work, try booting the phone in DFU (or pwned DFU if it failed). iTunes will then tell you that it detected an iPhone in recovery mode. Perform a normal Restore and this may fix the issue.
To check if the downgrade was successful, your baseband should show 05.13.04 (or any but not 06.15.00).
Let me know if it works :)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jerret Burton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 17
总计 343
