跳转到主内容
The RCA Voyager Pro tablet is a perfect entry into a world of wonder and entertainment. Running on Android’s Lollipop, the Voyager Pro is sure to excite and entertain.
48 个问题 查看全部
Forgot login pattern code
Can i bypass or rest login code if its forgotten
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hold power and volume keys down if you are booting. This should boot to recovery mode. Scroll with volume keys and press power button if you reached to factory reset option.
Update (01/12/2019)
Sorry. Hold volume up and power button only.
这个答案有帮助吗?
得分 1
1条评论:
Although I was hoping not to have to wipe data this was a spot on answer and worked perfectly
完成的
添加一条评论
添加你的答案
David Duncan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 141
