跳转到主内容
Repair information for printers made by Canon.
427 个问题 查看全部
ERROR B200 PIXMA iP7240
Hi all,
I have a Canon Pixma iP7240 and today, mid print for my test, the darned thing popped a B200 error message. This seems to be the print head that’s faulty. Although the net is full of ways to fix it, it’s just not for my particular model. Seems also just a clog which you wash out with water but I cannot get the print head portion out.
Does anyone have any advice for me?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
this error indicate that there is a problem with the cartridge. There are some steps here. The error is general for the cannon printers , not for a specific model. Try these instructions : https://appuals.com/step-step-guide-reso...
这个答案有帮助吗?
得分 0
2条评论:
Good morning Thanasis and thank you for your response. I was on that site yesterday. Throughout my search I noticed the error is not model specific but the repair is. That site you gave is brilliant but, because their model has a lever to lift their print head out, where my model doesn't, I can't follow that advise :(
I'm going to take my printer apart this morning and see what I can learn.
Will give feedback.
完成的
Ok good luck. If you are going to take it apart , would be good to clean it as well. Sometimes ink cartridge causes all these errors.
完成的
添加一条评论
I read a lot of different articles about printer error codes, and this code can also indicate a cartridge malfunction. I had this situation and I searched for a suitable cartridge for a long time because many cartridges were incompatible with my printer because of special characteristics. In addition, due to quarantine, I could not find suitable cartridges and I was just lucky that I came across the site https://www.mrdepot.ca and found there a huge variety of cartridges for different models. It’s just a terrific store, and besides, they are very loyal to their customers. The quality of the goods is simply excellent and after I installed a new cartridge, I no longer received error messages. So it seems to me that this can help you.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tina 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 20
总计 2,278
