跳转到主内容
期待已久的MacBook Air更新到来,带来了全新的英特尔酷睿i5处理器、升级了的视网膜显示屏以及众多其他更新。发布于2018年11月7日。
147 个问题 查看全部
Keyboard adding a period randomly after words.
My Macbook keeps adding a period after certain words while I am typing.
This doesn’t happen in all apps. I have noticed this happen mainly in the Outlook for Mac app, Whatsapp App and the google gmail while i’m logged onto it via chrome.
Not sure why, this is not consistent and doesn’t happen all the time.
When I restart my computer, it is better for a bit and then comes back again.
Also, the “ , “ was not working until I reset my laptop and it started working again. so i din’t think it’s a Hardware issue.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 7
9条评论
It can be but if after resetting your Mac keyboard is working fine there can be a software issue you can search for latest updates of the Os and after that update drivers then check if it is working fine there is no hard ware issue
完成的
I have this issue too and it is certainly more prominent in Outlook for Mac than in other apps. But it incidentally happens in Chrome (while typing this!) as well. The double space thing is not the cause, because the periods occur in the middle of words.
I also seem to notice that when the period is inserted, this is usually at a moment when some kind of lag occurs in the speed at which the characters that I'm typing actually appear on screen.
I just turned off all the switches in System settings relating to spell checking and auto-correct. This immediately had effect.
If you ask me, there is at most a minor hardware dimension to this problem, and the real issue is software. I think the reason why the problem occurs more frequently in Outlook for Mac is that I had both OSX and Microsoft monitoring and correcting my typing at the same time.
完成的
I'm having this problem too. I notice it mainly in Apple Mail and while typing in Gmail. I try to be very careful about punctuation and having to read through what I type isn't always doable.
完成的
me too..irritating as !&&*. adding a period after almost every word I type...as. it. is here...too
完成的
It is very irritating! It happens to me in Pages and on the Internet while typing in fields or in gmail. Though interestingly enough it is not happening now on this page.
完成的
显示更多的4条评论
添加一条评论
5个答案
已选择的解决方案
I would visit an Apple Store to have it looked at. I’m suspecting your keyboard is failing. As your system is still under warranty and Apple has been plagued by butterfly keyboard issues I would not except anything less than a replacement keyboard.
这个答案有帮助吗?
得分 3
1条评论:
I also take out an extended two year AppleCare warranty on any product I have problems with during the first year.
完成的
添加一条评论
最有帮助的答案
This may just be that you have left your keyboard with default settings which maddeningly insert a period if you hit your spacebar twice. I am old school, and still double space between sentences. Hence, the default puts a period there. Go to System Settings/Keyboard/Text and unselect “Add period with double space”. Hopefully this is the issue and will solve your problem.
这个答案有帮助吗?
得分 23
12条评论:
The iPhone & iPad do this, the MacBook, MacBook Air, MacBook Pro or iMac's don't do this.
完成的
Nope, this is true of my MacBook Pro.
完成的
My keyboard was doing this too and your comment helped me!!! Thanks so much!!!
完成的
I have new ipad 3 air and it is adding unwanted periods and screwing up my typing!
完成的
Thanks for the tip. It seems to have taken care of the problem.
完成的
显示更多的7条评论
添加一条评论
Check to see if the “Add period with double-space“ option is checked in the Keyboard settings in System Preferences.
这个答案有帮助吗?
得分 8
5条评论:
THANK YOU!! i would have never found this on my own
完成的
@Kai Dickerson No problem!
完成的
Thank you FIXED!!!!
完成的
I did that and it's still doing it!! 😭
完成的
@charitys_mom39 - Your keyboard needs attention! Your period key is messed up.
完成的
添加一条评论
Don’t forget that they’ve released this program since 2018:
https://support.apple.com/en-au/keyboard...
这个答案有帮助吗?
得分 1
添加一条评论
I turned off automatic period as well as autocorrect spelling in settings and it has helped immensely.
这个答案有帮助吗?
得分 0
1条评论:
How do you turn. off automatic period?
完成的
添加一条评论
添加你的答案
Mego Salbashian 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 50
过去 30 天: 164
总计 45,807
