跳转到主内容
Shark Ultimate Professional 1800-watt clothes iron, identified by model number GI505.
10 个问题 查看全部
Why does my shark iron temp setting light keep changing?
My shark iron is only 4 months old. When I set the temperature control light, it will not stay set. It runs up and down and may even turn itself off.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
My iron does the same thing and has done this since Day 1. The steam doesn’t always work either. I thought it was something I was/wasn’t doing right. I’ve had my iron for over a year.
完成的
添加一条评论
1个答案
已选择的解决方案
Hi @littleproblems ,
It appears that there may be a problem with the temperature sensor in the iron.
There is a 12 month manufacturer’s warranty on the iron.
As the iron is only 4 months old, I suggest that you contact the manufacturer as per the details in the manufacturer’s warranty statement that should have come with the iron, as to what to do to make a claim for a manufacturer’s warranty repair or replacement.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Sherall 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 819
