Will 2010 logic board fit in 2009 white unibody?
I have a late 2009 white unibody Macbook 2.26Ghz with broken logic board an was wondering if it's possible to replace it with the current 2.4Ghz white unibody logic board?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 1
评论:
I just found the answer to my own question, and I found it on iFixit :o
2009 logic board:
MacBook Unibody (A1342) 2.26 GHz Logic Board
2010 logic board:
MacBook Unibody (A1342) 2.4 GHz Logic Board
For both it says:
Compatibility:
All Unibody (Model A1342) 13" MacBooks
So it does fit! This is great :D
(for comparison, with the Airport (2009) card is says:
Compatibility:
2.26 GHz Unibody (Model No. A1342) 13" MacBooks
So this is different from 'All A1342')
(Edit: For some reason I'm not allowd to put enters in my text to make it look better....)
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
善于维修,即天赋异禀。
与 #ImAGenius 分享您的维修故事
我们都是天才
1个答案
已选择的解决方案
I would ask someone like www.welovemacs.com before buying. Here are the differences in the two machines, It looks like the swap may work with the exception of the trackpad. http://www.everymac.com/systems/apple/ma...
这个答案有帮助吗?
按维修分数 3
评论:
The guys from welovemacs weren't weather or not it would work.
I did some comparison form pictures, and it seems like it could fit. Most important question:
Are all screwholes and connectors at the exact same spot (and same connector)?
I'm right in the middle of tearing down the 2.26 GHz right now and noted that the teardown is the same on for both machines.
添加一条评论
添加你的答案
Perry 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 4
过去的30天: 7
总计 2,031
