跳转到主内容
Repair guides and support for your Philips TV.
220 个问题 查看全部
TV has bad horizontal lines and flickering image, help!
I recently was given a free Phillip's t.v. , model #: 55pfl5402/f7. I got it for free because the screen was flickering, but boy is it flickering. The whole screen flickers in and out with with black and white lines. Image is stable for maybe a second but not long. TV is a smart tv and connects to internet, loads up apps and everything. Seems like the only problem is the screen/lcd.
Could anyone point me in the right direction as far as what to check/fix?
Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Ashley Self  we really would need to see what it looks like. It could be an issue with the T-con board or the main board. See if you can post some images or short video about what this looks like. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 2
3条评论:
Thank you! I tried to when I posted, but I couldn't find the option
完成的
This could be a panel issue (bad gate drivers) as well. The large vertical lines are possibly a bad main/T-con board. This is going to be a tough one and I'd try a main board first
完成的
Ashley, did you find the solution? I have the same problem. I don't want to buy multiple parts if you can guide me. Was the main board or t connector? Thanks!
完成的
添加一条评论
添加你的答案
Ashley Self 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 87
总计 6,302
