Miele dishwasher G4210 is leaking from the bottom of the door.
I’ve checked the upper door seal, it’s all in tact and clean. Could it be the lower seal that’s leaking although it seems all fine and the machine is only 3 years old? Is this easy to replace? Thanks.
2条评论
I have this problem too, I think it may be the bottom door seal as it's coming from the door. Did you fix the problem?
由 gabbydavey 完成的
Hi, yes I fixed mine. It was actually the yellow clip that holds the tablet dispenser closed that had come away....one small hole where the cylinder part was held in place was letting water inside the door which then leaked from the bottom! I filled the hole and it’s been perfect since! Have to manually throw in the tablet now but I can deal with that!
Good luck with yours.
由 aysheapite 完成的
