跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
MacBook Late 2006 boots to white screen, but works on external monitor
I recently swapped the display in my Macbook Late 2006. It was cracked and I found a cheap working display on eBay . The Macbook boots okay but the display remains white. I connected an external monitor and the Macbook works fine with that.
Do you think it’s a faulty display?
Or is it possible I have connected the display cables incorrectly?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Sounds like you got the wrong display assembly. While they look the same they are not the same!
MacBook 13.3" Core 2 Duo Display Assembly图片
产品
$299.99
MacBook 13.3" Santa Rosa/Penryn Display Assembly图片
产品
$299.99
这个答案有帮助吗?
得分 2
2条评论:
Ok thanks. I’ll have a look.
Is there a way to check the display part number from System Profiler or using an app?
完成的
Plug in your systems S/N into here EveryMac - Lookup it will tell you the exact model you have as they both look the same.
Basically, the Intel graphics services (Intel GMA X3100 & Intel GMA X3100) is what defines which display is needed. As the signaling is different enough that each needs a unique display assembly.
完成的
添加一条评论
添加你的答案
Matt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 48
