跳转到主内容
An SSD, or Solid State Drive, is a type of storage device that uses NAND-based flash memory to store data.
iMac Late 2009 won't recognize external SSD at boot
Hello,
I’m upgrading my iMac Late 2009 from a 2 TB HDD to a 1TB Crucial MX500 SSD using the kit.
The 1 TB SSD when connected externally is recognized when I’m running High Sierra. When booting, the external SSD is not seen at all during in the Restore mode/Disk Utility screens. The USB 2.0 adapter seems OK and is seen at boot when another 1 TB HDD is connected at boot.
I’m able to install and boot High Sierra from that. Want to do the external check before removing the screen. Is this a known problem with Crucial MX500?
Read online somewhere to try Samsung EVO 850 due to a SATA link negotiation issue.
Would be so nice to save this iMac from the recycle.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Got the Samsung Pro 850 1TB working just fine. Will be returning the Crucial MX-500 in the kit. Ifixit folks, please take note and you may want to modify your kit!
Also, the metal drive adapter needed drilling out two holes with an 1/8 drill. The iMac original shock-mount stubs look like they use a 6-32 screw thread not the 3mm threads in the holes. The 6-32 threads were just the right size to self-tap.
So both the Crucial and Samsung SSDs were compatible with the kit’s USB 2.0 adapter, but the Crucial was not compatible on boot time with my iMac late 2009.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
It sounds like your SATA to USB adapter is not able to support the Crucial SATA III (6.0 Gb/s) SSD.
这个答案有帮助吗?
得分 2
1条评论:
See if this fixes your issue SATA to USB Cable with UASP
完成的
添加一条评论
添加你的答案
JOHN CHEN 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 699
