跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 个问题 查看全部
No Airport card installed issue iMac
So I just got done installing a 256GB SSD into my iMac 27" 3.4Ghz i7 that I just got and it has a 2TB on the 3.5 slot and everything boots fine and works good but No airport card installed is showing up. So I tried to reset my P Ram by Alt + Option + P + R and also unplugging power and hold down the power button to reset and also I just double checked connection with my wifi card to make sure its inserted property but its still showing no airport card installed...
any help would be great...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Go under the Apple in the upper left hand corner to "about this Mac", more info, network, Airport and see if the computer sees the card. If not, take the card out then reseat it, replace the cables and check again. If it still fails, replace it.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
mywapple 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,162
