跳转到主内容
Repair and support information for HP Laptops, designed for home and home office use.
794 个问题 查看全部
How do I fix sunken keys in the middle of the keyboard
I have sunken keys in the middle of laptop keyboard due to poor installation by the service person and I have been refused further service.
All the keys in middle of the keyboard and sunken, and it is due to having a lack of support under the keyboard., however it is still functional.
If it is relevant , the keyboard model is HP Pavilion - 15-bc231tx
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
I will be grateful for any suggestions! I am completely new to self repair.
完成的
添加一条评论
2个回答
最有帮助的答案
Remove the keyboard and see if the supporting base has been bent inward. Here’s how to do it:
https://www.youtube.com/watch?v=BWZQ9opN...
UPDATE
This video should show you how to get to the battery:
https://support.hp.com/us-en/document/c0...
这个答案有帮助吗?
得分 3
评论:
Hello mayer, thanks for your answer! I have a few questions to ask. My laptop model has an inbuilt battery, is it necessary to remove it? If so , how do I do so?
Also, the keyboard does not come off the top but rather it is under the laptop casing, any tips on that?
Thank you mayer
完成的
If the supporting base has been bent inwards , is there a fix or anyway to put in a support for the keyboard?
完成的
I am not familiar with your model. First see if you can determine if this is the problem. You would probably need to tear it down until you can get to the bottom side of the keyboard and push it back up.
完成的
添加一条评论
Try unscrewing the back of the keyboard and if something is out of place, put it back to where it was. If some springs are broken, order replacements. If nothing is visible that is causing the problem, contact the manufacturer.
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
Peck Hua Liew 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 14
过去的30天: 93
总计 2,007
