跳转到主内容
Guides and repair information for the Lenovo Thinkpad T430, a 14-inch business laptop by Lenovo.
25 个问题 查看全部
Why Arma3 game is not responding?
I have lenovo think pad 430t with 4 gb ram and 500 Gb disk space and Intel 5i with windows 7 64 bit, “Arma3 is not responding” , game minimum requirement is 4gb ram, 25Gb Disk space and duel core predecessor but still not working I tried following
1) Updated Display drivers
2) Deleted temp,and other junk files
3) checked disk and ran memtest
4) Disabled antivirus and firewall
5) Other games are works fine even heavy games like WOT, COD modern war etc
6) Reinstalled game but same issue
7) Ran in compablety mode
8) Tried in different user account
9) Ran as administrator game pop ups for 0.5 second and closes and right bottom corner notification comes about resolution so i checked with setting different resolutions but same issue
Please help and thank you in advance :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Is this limited to only Arma3? Do other games run without a problem?
完成的
添加一条评论
1个答案
In case you run cracked software, i recommend you first should spend money on buying the game.
Once you have done that (or if you already use legit software) , check the crash report ( https://community.bistudio.com/wiki/Cras... ), and get help the bohemia troubleshooting forums. (thats where they were intended for.)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
yalawolf 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 109
