跳转到主内容
修复你的物品
维修的权力
商店
A1706/EMC 3071—于2016年11月上市,这台13''MacBook Pro带有OLED触摸条。以双核“Skylake”英特尔酷睿i5 CPU和4个雷电3端口为特征。
163 个问题 查看全部
MacBook Pro Touchbar no backlight on new screen
Hey Gang!
Wondering if you guys have any ideas on how I can get this sorted out.
Here in the office, one of the MacBook Pro 13’’ Touch Bar has a small amount of liquid damage according to Apple and that’s why the backlight wont work. Apple actually replaced the screen on this laptop anyway under the quality program but the issue persists.
System works fine with an external display and if a flashlight is held against the laptops screen one can see the desktop images.
Wondering if there are any simple repairs one can do, or if there is someone in the UK that does logic board repairs just like Louis Rossmann?
Thanking you in advance,
rafa
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Can you tell us which model you have 2016, 2017 or 2018?
完成的
hey dan, sorry, should've mentioned. 2016 model.
完成的
添加一条评论
打开所有标签
Mac的RAM升级套装
购买套装
所有选项卡都有足够的 RAM
购买套装
1个回答
最有帮助的答案
I’m thinking they didn’t fix the issue. This series has a known issue with the displays ribbon cables. If you slowly raise or close the lid around 45 degree’s the display will wink on or off. The ribbon cables are part of the lid assembly and can’t be replaced. Here’s a good view of the connections:
I would go back to have the display assembly replaced again (under the repair warranty). The only other possibility is a defective Hall sensor which is part of the logic board on the backside
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Rafa Neves 将永远感激不已
浏览统计数据:
过去的24小时: 2
过去的7天: 13
过去的30天: 61
总计 1,279
