跳转到主内容
iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
118 个问题 查看全部
What Should I replace on my IPad?
Hi, I’m relatively new to the realm of Ifixit and am not sure what to replace on my IPad Air. The screen is moderately cracked but ghosting occurs and some areas of the screen do not respond to touch. Should I replace the LCD along with the front panel?
Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个回答
已选择的解决方案
You’ll need to replace the front panel. The LCD is OK as long as it still shows display and no horizontal or vertical lines.
Before installing the new front panel you’ll need to bend back that top right corner so that it sits in properly.
iPad Air LTE Front Panel Assembly Replacement
iPad Air Screen Digitizer
iPad Air Screen Digitizer图片
产品
$39.99
这个答案有帮助吗?
得分 3
评论:
Also, once I remove the front panel, do you think I’d be a good idea to clean the LCD? If so how?
完成的
添加一条评论
Ok. First of all, this is extremely hard to do. You need to invest in the right tools and other things. Next, iPads are WAY more fragile than iPhones. One wrong move and no more iPad. It would be a little bit more expensive taking it to apple, but there would be NO risk. That’s what I recommend.
这个答案有帮助吗?
得分 0
评论:
Well, I'd rather attempt to fix it for $50 rather than pay $249 for Apple to do it.
完成的
@jflys5000 Hey Jackson! I've looked at all your answers. Please just stop, you're helping no one.
完成的
Look @mayer idc. I’m just throwing out suggestions. Why do u gotta be all up in my business? Jeez dood. Go away.
完成的
@ronald you could loose your $500 iPad. Your call tho.
完成的
添加一条评论
添加你的答案
Ronald 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 63
