跳转到主内容
一个广泛的电子产品维修指南,从家和汽车音响到计算器。
15006 个问题 查看全部
Can you fix a Fiio X5 second generation MP3 player.
Is it possible for you to fix a Fiio player.
Everything works except for the sound that should come out of the headphone jack… Nothing works there is no sound comes out of it. Not resetting the player or anything works. I’m thinking the headphone jack inside is disconnected or the amplifier for the player burned out I don’t know. There’s also a line in where I can plug in my headphones and that works just fine just a bad quality
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
已选择的解决方案
If the connection from the motherboard to the headphone jack is bad and it needs to be re-soldered, then you could fix it, but, if the actual headphone jack is broken (Fiio shows headphones connected, but no sound) then you couldn’t fix it without a new headphone jack. You also can’t get a new headphone jack online, so you would need to get a warranty. You can check warranty status here:http://check.fiio.net/. Also, there is info here: http://www.fiio.net/en/agreement
这个答案有帮助吗?
得分 0
评论:
I sent Fiio this information a week ago. They replied and told me to reset the device, try other headphones and try restarting it. I did all of that and nothing. I emailed them back. I just need to send it in for repair. They just take forever to get back to me. I need my $300 player that I bought from Amazon to work. It stopped working while I was literally listenening to it
完成的
You most likely pulled on the cable and broke the headphone jack. It happens all the time when people are careless.
完成的
添加一条评论
添加你的答案
Homeboy88 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 6
总计 353
