跳转到主内容
Repair guides and troubleshooting for the 40in LCD TV with model number LA40R81BD or LA40R81BDX. This television was released in early 2007.
44 个问题 查看全部
Samsung UN60EH6050F has audio, dark blue screen
My Samsung UN60EH6050F is having a picture issue. I can hear the audio playing but all that is present is a very dark blue screen. I’m thinking either the backlight or T CON board from what I have read, but need more insight. It would not let me select my exact model the above tv is not mine.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Im having the same problem if possible I would like to know if the t-con was the issue or was it something else?
完成的
添加一条评论
1个答案
最有帮助的答案
Kristen Todd  shine a flashlight at an angle against the screen If you can make out shapes etc. it is your backlight. You can of course also remove the back from your TV and take a look at the small openings in the metal to your LCD. If the backlight comes on, it will shine through those openings. You can also disconnect the mainboard from the power board and then turn your TV on. It should come one with the backlight only (no sound/no picture). If it is the backlight you will have to do some voltage measuring on the power board as well as the LED connector. Let us know what you find and if you can post some images of your boards with your question. That way we can see what you see. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 1
评论:
My backlights shine through the back. And I can't see anything with the flashlight just a dark very dark blue screen ( can tell its blue because it goes completely black when I turn it off)
完成的
So you can see the backlight turning on? If you backlight turns on then go ahead and measure the voltage on the T-con board fuse. You should get around 12V
完成的
Yes the backlight turns on when the tv is on. If the backlight isn't the problem it's more than likely the t con board correct? I will try to measure the voltage this week.
完成的
Kristen Todd I'd go with the T-con board then the main board....
完成的
添加一条评论
添加你的答案
Kristen Todd 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 3
过去的30天: 19
总计 2,437
