跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
Touch screen not working after screen replacement
Hi all, I do a lot of work in repairing iPhones for people however i have never had this issue happen. I got given an iPhone 6S Plus to change the screen and battery on, everything worked fine before i started working on it. However after transferring the screen the touch screen wouldn’t work, it isn’t detecting any touch what so ever. Everything else works. I put the old screen back on and that doesn’t work either now. I disconnected the battery before working on it so it couldn’t of being a short and all the connectors and cables are in perfect condition and are not broken. I suspect it could be an issue on the logic board but I am unsure. I have even re-installed the iOS to see if it was software but it doesnt seem to be. Does anyone have any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
The Touch (logical) circuitry is located on the screen so if both the original screen and replacement screen no longer work, then the issue is most likely with the Touch power lines which still come from the logic board. This could be caused by a defective replacement screen damaging the power circuit.
If the connectors look good (sorry, blurry pictures don’t help), then the next step would be to have the phone looked at by a micro-soldering tech.
这个答案有帮助吗?
得分 2
1条评论:
I'll try and get a tech to look. Thanks for the help.
完成的
添加一条评论
Hi! I suggest closely inspecting the connectors for the digitizer on the logic board. [Look Near Here.|stepid=113333]] Also look in the surrounding areas for any other connectors that may have been knocked off. Look very carefully as the parts are quite tiny.
这个答案有帮助吗?
得分 0
添加一条评论
Closely inspect the connectors for the digitizer on the logic board, (look near here).
Also check surrounding areas to make sure any other connectors have not been unplugged.
Hope I could help.
这个答案有帮助吗?
得分 0
1条评论:
I have had a good look around them and nothing seems out of the ordinairy, i took some photos but they are a bit blurry.
https://b.catgirlsare.sexy/Mo7G.jpg
https://b.catgirlsare.sexy/k9PS.jpg
完成的
添加一条评论
there are filters for touch right where people typically pry the fpc connector off. you may of accidentally knocked it off during disassembly, ive seen it before a couple times.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tristan Pasoe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 480
