Repair guides and support for your Philips TV.
nadermostafam @nadermostafam
声誉积分: 1
发帖于: 2018年12月26日
The television voise stell of however I disconnect the cable of the outer speaker form the tv
这是一个好问题吗?
1条评论:
Hi,
Could you explain more clearly what you have done to fix the sound from your TV?
If necessary edit the question (click on Options > Edit) and write the question again in your own language as your current question is difficult to comprehend.
Also what is the model number of your TV?
由 jayeff 完成的 2018年12月27日
Kevin Sargent @customsarge
声誉积分: 601
3
发帖于: 2018年12月29日
I’ll wager it still senses the external plug. Insert and remove the plug several times to scrub the contact.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 27
Hi,
由 jayeff 完成的
