跳转到主内容
Vizio 42" LED TV released in September 2012.
45 个问题 查看全部
Colorful vertical lines started appearing on my TV
I turned on my TV yesterday and they started working perfectly fine then it turned off by itself I turned it back on after like good 2 hours and colored vertical line started appearing only when I turn on my Xbox that's hooked up to it it's the only time we'll start going off I tried with my we start doing that too and I try to keep my PlayStation start doing that also I need some help how do I get rid of them cuz I just got this TV
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
If you just got the TV, does that mean you just bought it or got it used? If you had just bought it, take it back to the retailer and ask for an exchange as it’d be under warranty I’d assume.
However, if not, make sure all connections are tight, and try a new HDMI cable.
However if you tried both of those and none of them fix your problem, you may need to look into either finding a LED screen that supports it and repairing it yourself, or take it into a TV repair shop.
Hope I could help.
这个答案有帮助吗?
得分 1
添加一条评论
On TV, make colors settings, not working
Update (07/03/2022)
This is my phone number6822607730
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
tyler makar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 253
