跳转到主内容
加入维修社区 - 创建账户
Phone keeps vibrating and won't turn on
Hello
My phone switched itself off and is now vibrating twice and keeps flashing the samsung sign.
I downloaded an app off Playstore yesterday and everything seemed okay. But now it is not working properly.
I tried to do a reset but it is still not working.
Help please
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
HPhone keeps vibrating and won't turn on
完成的
My samsung j1ace suddenly tripped off. When I tried turning on it started vibrating and the screen was blank. Pls what can I do?
完成的
添加一条评论
1个答案
已选择的解决方案
May I know the app you downloaded?
This ‘app’ may of downloaded malware to your device and caused the phone to keep shutting itself off.
Otherwise, try the following steps;
Step 1. Open the back cover of your Note 4, remove the battery and wait a couple seconds, then insert it again.
Step 2. Hold the volume up key, power button and the home button simultaneously. When the ‘Recovery Booting…’ text, release these buttons.
Step 3. Select the cache option and press reboot. If this doesn’t work, repeat Step 2, press the cache option, and select format device. (Note! Formatting your device will wipe your device clear of all files.)
Hope this helped!
这个答案有帮助吗?
得分 2
3条评论:
Hi I downloaded Wordscape.
I have tried step 1 and step 2.
I have attempted to try step 3 and it said Recovery Booting, I released the buttons and it said installing system update and keeps restarting again.
完成的
Oh ok, instead of me explaining it and getting you to understand, please watch this helpful video on YouTube: https://www.youtube.com/watch?v=KCocwC50....
Edit: Also, try just letting it keep restarting when it's installing system update, after a preset amount of time it will stop restarting and give you the normal recovery options.
Hope this helps.
完成的
Thankyou. I will have a look at this video :D Hopefully, it will help.
完成的
添加一条评论
添加你的答案
alishasamms305 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 31
总计 9,385
