跳转到主内容
修复你的物品
维修的权力
商店
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
721 个问题 查看全部
Replace Broken Screen - Few Questions
Hello,
I want to figure out exactly what I need and need to do to replace a broken screen for an iPhone X. When I check the iFixIt page for iPhone, it shows “screen and digitizer”. So there are two parts. First off, what exactly is the digitizer? From what I understand, that is what gives the iPhone touch capability - is that correct? How do I know if I need to replace just the screen, digitizer, or both? Lastly, is there a big (noticeable) difference if I replace the screen with LCD as opposed to AMOLED?
Thank You!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个回答
最有帮助的答案
there are 3 different replacement screens qualities on the market. aftermarket lcd aftermarket oled and oem refurbished. in my opinion the am lcd is trash and dont waste your money. the am oled is the way to go for price vs quality. its hard to distinguish between am oled and oem oled. just do youself a favor and dont use the lcd.
这个答案有帮助吗?
得分 1
添加一条评论
Firstly when you buy a screen it will come with both the screen and digitizer. Which is fine and you can easily assemble this into the phone, if you replace with a LCD instead of OLED then you will notice a change as the LCD is not as sharp as OLED and the LCD also uses a backlight which OLED does not
这个答案有帮助吗?
得分 0
添加一条评论
You CANNOT peel the screen from the front glass or digitizer, this requires professional equipment and still has very high failure rate and bad overall quality no matter how careful you try to be.
From now on ALWAYS treat the front glass, digitizer (if there is a discrete piece of it) and the display as one unit.
I don’t think you can replace the screen with different type. I’ve heard some brands of aftermarket iPhone display panels but I don’t think there is an IPhone X LCD variant.
这个答案有帮助吗?
得分 0
评论:
for having 43K rep you dont seem to be very experienced in iphone screen repair......you CAN "peel" the glass from the lcd. it does require professional equipment but an experienced refurbisher should have no issue with "high failure rate" or "bad quality" in fact thats how you get the best quality replacement screens.
and there are 3 different quality screens on the market for iphone 10 currently. am lcd, am oled, and oem refurbished.
完成的
Actually there are 4 if you include aftermarket TFT iPhone X.
完成的
We are talking iPhone X here. You can peel LCD easier, but try your luck on flexible OLED panels, very few refurbishers can easily and reliably refurbish iPhone X screens. It’s super easy to damage the screen during disassembly and vacuum bonding process. Most repair shops only offer intact screen assemblies taken straight from other phones in China, and we are talking about the China where everything is possible here.
完成的
添加一条评论
if its just the glass that's cracked and everything works as it should then get a replutable company who do a glass only repair/replacement so you keep the original quality. if the OLED is broken then find a good quality replacement (one whole unit).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ezra Shiram 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 109
