Move apps from an iPhone to another iPhone without iTunes and iCloud
Hi,
I would move two Apps fom my iPhone 4S to another iPhone 4S, but there is a problem: these apps aren’t again on App Store, so also if I use iTunes for restoring a backup, these apps aren’t again on new device (in my case, is another iPhone 4S).
There is a solution about this? Is possible move an app that is on an hard disk of an iPhone to another without iTunes and iCloud? Because I noticed that if the apps that have been removed from App Store can’t be re-installed on another device.
I hope there is a solution, I’ve also Cydia that could help.
Thank you in advance.
If you installed the App via the App Store you've bought it and you can re-install it to your new iPhone without issue as long as you iOS will support it.
If on the other hand, if you are trying to install it on someone else's iPhone that won't work.
由 Dan 完成的
