跳转到主内容
Repairs for a broad range of sound-generating equipment including speakers, sound bars, and speaker components.
2687 个问题 查看全部
Studio speakers Mackie CR5BT no sound
Hello guys
I’m user of Mackie CR5BT. Worked for me very good last 15 months till today.
I switch on my computer and no sound. I checked all cables , also by bluetooth, nothing work , silence. When I put headphones to headphone connector on front panel , normally work in headphones sound , that connection from computer to speakers working good.
Any advice how fix it ? I found some from CR3 version, to connect and unconnect headphones , but it is not work in my CR5 version.
Thanks in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Start by looking in the user manual. If you’ve lost your manual, go to this link for a PDF: https://mackie.com/sites/default/files/P...
In the manual, go to the “Troubleshooting” section and look for the heading ‘No Sound’' for some simple checks to perform, e.g. to see whether the speaker set has power & whether the problem is just in one speaker (in which case it could be a bad cable).
If no joy, and you’re still under warranty, the next page gives instructions for pursuing repair under warranty. If you’re not under warranty, you’re faced with a more difficult situation. For more expensive Mackie speakers & gear, helpful info is available such as block diagrams, schematics, etc.; but for your speakers, this doesn’t seem to be the case. It could be something relatively simple, but if you don’t have electronics repair experience, it might too much for you.
If there’s a local repair shop near you that works on things like stereos, amps, TVs, etc., it’s possible they might be able to fix it for a reasonable cost - again, if the problem is something simple, which it probably is.
这个答案有帮助吗?
得分 2
3条评论:
Hello Randy
Thanks for your answer. This all I know what you wrote. I’m ham radio operator and I know something about electronic. Problem is I’m in Asia now far from home, and dont have any electronic stuff with me. I found on forum some advice about model CR3 and CR4 , with headphone socket and cut pin 5 in chip TDA7265 … I made this post to find someone who had same problem but with my model CR5BT. My speakers out of guarancy now. That only I can open speakers and cut pin 5 on chip if someone confirm me it , also who did on own speakers.
完成的
COMMENT PART 1 - This part of your original post is confusing to me - it's a matter of the wording: "When I put headphones to headphone connector on front panel , normally work in headphones sound , that connection from computer to speakers working good."
Do you mean that when you plug headphones into the headphone port on the front panel of the left-hand Mackie, everything works as expected? Meaning not just sound, but the volume knob on the Mackie works to control the volume?
If so, then I would suggest editing the title of your question to make this clear. Besides that, I guess it would be good news that headphones still worked - in the sense that perhaps there is just a problem with muting of the speakers occurring, as in the case of the CR3 where someone did a rather ugly fix by cutting the mute pin on the chip.
完成的
COMMENT PART 2 -
Continuing -
On that same thread about the CR3, someone else mentioned an easier way - just get the headphone jack to work properly again. One of the spring contact points in the jack acts as a switch & if it is connecting when it shouldn't be that would engage the mute. So if if it were me, I wouldn't do surgery on the chip (regardless of whether it's a TDA7265 or some other chip), I'd try & see if I could take apart the speaker enough to get that jack out of its socket & see if it's the problem; if so it could be easily replaced.
If you don't have any tools w/ you, you might not be able to do such work easily - but you could at least try plugging & unplugging a cord into the headphone jack to see if that would free up the contact switch?
At any rate I think whatever you do, without a schematic or anyone else posting on the web about this problem, you're on your own in terms of trying to solve it. But as I would say I would try & fix the jack before I mutilated the chip.
完成的
添加一条评论
This is an old post I'm responding to, but just wanted to say I had the exact same problem. All of a sudden, no sound. But, I did discover that if I plugged in the headphones PART WAY, the speakers would work as normal. And, the headphones jack worked also, if I plugged in the headphones all the way.
Then after maybe a few weeks, the speakers returned to completely normal where I didn't need to plug in the headphones part way. They worked fine . . . for about six months or so then the same problem occurred and this time the trick of plugging in the headphones part way didn't work. I didn't have time to mess with it so I just bought new ones, but I would like to get the old ones working because it seems like it may be a simple problem. It seems like maybe the headphone jack has gone bad and is not switching the electrical path correctly, or at all.
Anyway, I just wanted to weigh in and see if anybody has any new info on this issue.
Thanks.
这个答案有帮助吗?
得分 1
1条评论:
I just tried your method of plugging into the headphone part way and magically my CR5BT started blasting again. Thanks.
完成的
添加一条评论
添加你的答案
Mayllo 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 44
总计 4,829
