跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1199 个问题 查看全部
iPhone X Face ID won’t detect faces
So I recently purchased a smashed Iphone X and an Icloud one in order to get a working one. I basically put the motherboard, front camera and the sensors from the screen into the Icloud one and everything works except from the fact when I try to set up Face ID. It tries to detect my face but nothing happens then proceeds to say Face ID is unavailable. Any idea what could be the problem?  It lets me try and set it up so I know all the correct parts are there as it can activate it but it just can’t see my face
thanks in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
FaceID and the logic board are paired. Only apple can re-pair them.
这个答案有帮助吗?
得分 3
4条评论:
I know that’s why I also changed over all the parts connected to the Face ID
完成的
Update: just reset it back to factory settings and it now works, seems to have been a software issue
完成的
apologies on what happened back there. we had a slight... issue.
完成的
The children have now been removed. Cammy, if this answer solved your problem please accept it so it can be archived to help others.
完成的
添加一条评论
添加你的答案
Cameron 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 764
