跳转到主内容
Green Light turns on in my apple power adaptor. Doesn't charge
So my power adaptor broke 3 months ago so i took another charger and took the magsafe connector and connect it together. it connects and green light turns on but doesn’t charge i tried it with another macbook and it charges.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Sadly, you damaged your charging logic inside your system.
Often times when the MagSafe cord fails it can short out the signal line which then damages the charging logic. Review this Apple T/N to make sure you’ve got the correct MagSafe adapter and the cable & connector are both in good shape. I don’t recommend patching the MagSafe cable as you did here Apple Portables: Troubleshooting MagSafe adapters
As to fixing your problem you’ll need to work up the chain starting with replacing the DC-In Board following this guide MacBook Pro 13" Unibody Late 2011 MagSafe DC-In Board Replacement If that doesn’t change things you’ll need to get someone to fix the logic board.
这个答案有帮助吗?
得分 2
6条评论:
Hmmm i just shaved off a bit of plastic from the MagSafe and it works!
The part that connects to the MacBook because it wasn’t getting good connection
Thanks though
完成的
@zantheproplayz - Thats why I was recommending you replace the DC-In Board as the plastic can soften up from over heating.
完成的
i completely removed the dc in board plastic..
完成的
Please get a new one as you don't want a short!
完成的
too expensive..
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Zander Castillon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 60
