跳转到主内容
The Honda CR-V is a compact crossover manufactured by Honda since 1995. Since It uses the Honda Civic platform in an SUV body it was called "CR-V" which stands for Comfortable Runabout Vehicle.
air con panel bulbs
the bulb behind the climate control guide is dead. how do i change it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Are you sure that if the air conditioner works, but the light does not go on, that is the problem?
完成的
Yes, because the technique is faulty and can cause other malfunctions.
完成的
添加一条评论
1个答案
最有帮助的答案
Hi,
You don’t state the year of your model CR-V, but here’s a link that shows how to replace the Climate Control HVAC/Heater/AC light bulb for a 2003 CR-V EX that may be of some help.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
silvergrey92 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 7
总计 288
