跳转到主内容
Released in Japan on December 12, 2004, in North America on March 24, 2005, and in Europe on 1 September, 2005.
101 个问题 查看全部
My PSP is bricked and I don't have another one, help?
After trying to homebrew my PSP Fat/Phat, i turned it on and this is what happened:
-After flashing some 1.05 OFW files on it, i turned it off
-I turn it on again and the screen is completely black
-Check the battery to see if anything is wrong
-Turn it on again and try every single button
-Nothing
I only have Mac OS X so i cannot do things PC might do, i also have a Pandora battery and a 4GB Memory Sitck
Just on a side note:
It was running 6.35, then i installed 6.35-B5 but every time i turned the device off, it returned to normal and then i tried to downgrade it so i could install 5.50m33. It's model number is a European 1001, if that helps in any way
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
You have a Pandora Battery, so you're in luck. You will need to make something called a magic memory stick. (Basicaly, you'll use a special tool to add recovery files to a normal memory stick) There are a few different guides and tools that help you do this on a Mac. Once you make the magic memory stick, plug it into the PSP, remove the battery, and hold down the Left Bumper. Now, while holding the left bumper, insert the Pandora battery. The PSP should turn it on, and show a menu. Scroll down to "Install 5.00 (Or 5.03 if it shows it) OFW" The PSP will now reinstall stock firmware. Remove the magic memory stick, and reinstall the original battery. The PSP should now be unbricked, running stock 5.0* firmware.
这个答案有帮助吗?
得分 0
添加一条评论
http://www.youtube.com/watch?v=rRve4z5DM...
^ How to make a MMS the real easy way
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rafael Carrilho 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,106
