跳转到主内容
了解您在设备上维修可能所需的技能。
87 个问题 查看全部
Microphone cuts out when bent at certain angles [Rosewill Nebula GX10]
I bought a Rosewill Nebula GX10 from Newegg for black friday for about $10. It’s been like 2 maybe 3 weeks now and the microphone has stopped functioning. But to be more specific, it stops functioning after I bend the microphone itself on the headset past a certain angle. In the picture, the green area is where I can place the microphone while still receiving feedback . In the red area, the microphone cuts off and I don’t see or hear any audio coming from the mic. I know the problem doesn’t lie with the jack nor the cord as I’ve messed around with different jacks from different computers and oriented the cord in every manner I could think of. Using Windows’ built in audio settings and discord to verify audio input from the mic. Any ideas as to what specifically is the issue before I take apart the headset?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The microphone itself should have a pair of wires running inside the armature and into the main body of the headphones. Because you are noticing the issue change states as you mechanically manipulate them, I would guess a loose wire or solder point that is pulling into contact when the arm is up, and loses contact when the arm is down.
这个答案有帮助吗?
得分 1
1条评论:
Thanks, I had a feeling that was it. Now to find an entry way into the headset without disassembling the entire thing (if it's possible) :P
完成的
添加一条评论
添加你的答案
Miguel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 1,135
