跳转到主内容
发布于2015年3月,并在2015年4月10日上市。盖乐世S6是盖乐世家族又一部旗舰机型。其曲面屏版本被称为盖乐世S6 Edge。
487 个问题 查看全部
Can I put in GS6 Active's battery in a normal GS6? Will it work?
Hello my name is Cris,
I got a second hand S6 and the bettery is draining suspiciously fast.
I was considering the idea of buying and putting the battery of a Galaxy S6 Active into this Galaxy S6. The spec and sizes of the batteries are the following:
S6A capacity 3500 mAh / 13.48Wh volts: 3.85VDC size: 92 x42x5(mm) (long/wide/thick)
S6 capacity 2550 mAh / 9.82Wh volts: 3.85VDC size: 96 x 45 x 4 (mm)
So the battery from the S6 Active is shorter by 4 mm, narrower by 3mm and thicker by 1mm.
Image of batteries: https://imgur.com/a/Rfvn96M
What do you think? Would it work and last longer? Has this been done by anybody? I googled a lot but dont find any content about this.
Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
I am too unsure if a S6 Active Battery will perform better but I am certain that iFixit has the best batteries in town. Try one from them: Galaxy S6 Battery
Galaxy S6 Battery图片
产品
Galaxy S6 Battery
$26.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cristi Cristi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 49
