跳转到主内容
iMac 是 Apple 的一体机台式电脑产品线。
7081 个问题 查看全部
Separate the slab from the glass on a 2017 iMac 4k screen!
Bonjour,
En démontant l'écran de mon iMac de 2017, j'ai fêlé la vitre qui est désormais lié à la dalle 4K. La dalle est intact, pas la vitre que je voudrais changer seule pour minimiser le coût financier. Est-ce possible ? Bidouilleur bienvenue ;)
Hi,
Disassembling the screen of my 2017 iMac, I cracked the glass that is now linked to the 4K slab. The slab is intact, not the glass I would like to change alone to minimize the financial cost. Is it possible ? Welcome bidder ;)
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
Apple Watch 套装
Screen and battery repairs just got easier.
现在开始购物
Apple Watch 套装
现在开始购物
2个回答
已选择的解决方案
The glass is fused using the same adhesive that is used for cellphone display glass. You can pick it off, slowly and carefully, using a heat gun/hair dryer, patience, and extreme TLC. This process risks both scratching the LCD surface and utterly breaking it due to the flexing force of the glass you are attempting to pick/peel off.
Once completed, you would need to find a supplier of the glass, alone. You can use UV glass adhesive to bond a new glass to it, but you would need some sort of vacuum chamber system to remove all of the air bubbles. It might be more worthwhile to buy a new assembly and sell your damaged one as parts. There are groups that buy them so they can refurbish and resell them.
这个答案有帮助吗?
按维修分数 2
添加一条评论
Thank you Isaac for your answer. I'll take your second solution ... Apple definitely makes disposable products, it's sad for the consumer. Greeting.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Pilou8386 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 32
