跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
873 个问题 查看全部
Rear camera won't fit in new back housing
The back on my iPhone 8 was cracked so I replaced the housing. I’m trying to put the rear camera into the bracket but it won’t go in. It seems like it’s a bit too narrow on one of the corners. I’m trying to bend the frame of the bracket but I don’t want to stress it too much with the fear of breaking another back housing!
Any suggestions?
**Edit** I’ve added a picture that shows the original bracket from the broken back housing compared to the bracket in the new aftermarket housing. There is a discernible difference in the shape of the bottom corner that is stopping the camera from sitting in it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Is this an original housing replacement housing (for example, pulled from a defective device) or is this an aftermarket one? Some aftermarket housings have poor tolerances which can cause this kind of issue. Don’t torque the rear-housing too much because you will crack the glass and then have no recourse with the supplier.
Inspect the opening and compare it to your original housing. If you have a digital caliper, take some measurements to see if there is truly a difference or not.
这个答案有帮助吗?
得分 2
1条评论:
It’s an aftermarket replacement that was never used. It appears that the bracket is definitely a different shape on the bottom right corner. I’ve attached a picture - in the picture you will see the original bracket from the broken housing (snapped it off after transferring all the contents over) sitting on top of the new one. The original looks to have an extra gap in the lower right corner of the rear camera bracket, whereas the new one is flush. I've added an image to the original post that shows this.
完成的
添加一条评论
添加你的答案
Bill Shannon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 114
