跳转到主内容
不间断电源,UPS或备用电池/飞轮,是当输入电源(通常是主电源)发生故障时向负载提供应急电源的设备。
42 个问题 查看全部
apc Back-ups cs 500 amber on battery light flashing
i just bought a ups and it is flashing the on battery light rapedly. it does this even with a battery removed. any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Check your AC outlet! You have a mis-wired outlet.
APC UPS Users Manual
Point #4
Check site wiring fault indicator (rear panel-top)
A lit indicator means that a shock hazard exists due to faulty building wiring , that should be corrected by a qualified electrician.
If the building wiring fault indicator is lit, one of the following conditions exist:
• Open or high resistance ground• Hot and neutral polarity reversal• Overloaded neutral circuit
Note: Improper building wiring will not prevent the UPS from operating but will limit it's protection capability. Faulty building wiring could result in equipmentdamagethatisnotcoveredbyAPC. Please refer to APC's Equipment Protection Policy for details.”
这个答案有帮助吗?
得分 2
3条评论:
Power Gear 3-Wire Receptacle Tester
https://www.walmart.com/ip/Power-Gear-3-...
完成的
wall is fine
完成的
Nope! You have improperly wired outlet. You may have the issue in the fuse panel or a device which is shorted to ground.
Best to get an electrician in to service your wiring.
完成的
添加一条评论
添加你的答案
jake 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 11
总计 1,939
