My iPod got wet, what could have happened?
what happened when the ipod was exposed to water?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
Define "exposed to water". Are we talking about a drop or two or water landed on the screen, someone spilled beer on it, or it took a dive in a swimming pool?
完成的
If it has water damage you should either take it apart yourself or take it to a reputable repair shop for a water damage treatment. Also if it was dropped in the toilet let someone know that before they touch it, you would want to know first.
完成的
Home sprinklers opened up on it in a garage fire, and soaked it.
完成的
If battery had some charge quite a bit of troubles might have been started as soon as water reached the connector, starting from battery charging and power supply circuits, main power IC and so on, depending on how much water reached in and the battery power. Most probably screen is also in a bad shape.
完成的
添加一条评论
