跳转到主内容
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
281 个问题 查看全部
Why is my MacBook shorting out?
I got a 2015 retina macbook and the only thing wrong with it is that the computer was opened wrong and the cables tore. I replaced the cables I thought looked damaged and now everything turns on except the display. So I started messing around with the cabels trying to find where the problem was and I found that when I unplug the cable going from the track pad to the keyboard the screen turns on and even the mouse works. When I plug the keyboard back in the screen, track pad and the keyboard turn off. But external display still works. Wondering if the whole keyboard is garbage or just the cable? Or is it the logic board?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Sounds like you may have damaged the sleep sensor, When connected even though the display is open your MacBook thinks its closed and the screen turns off you could test this theory with InsomniaX, this will make your Mac think the lid is constantly open regardless of the sensor.
https://www.macupdate.com/app/mac/22211/...
If it is the sensor as far as I know they are attached to the keyboard and it cannot be replaced on its own.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Benjamin Osmun 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 258
