跳转到主内容
Fix Your Stuff
Right to Repair
Parts & Tools
Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
182 个问题 查看全部
问题已关闭
automatic transmission not shifting
transmission not shifting properly
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
My recommendation would be that you try a place like Autozone or your local mechanic and have it hooked up to an analyzer. It is very difficult to diagnose since there are lots of reasons why your transmission does not shift right
完成的
添加一条评论
1个回答
First thing: check your fluid if you haven't already. Lack of fluid or worn out fluid can cause automatic transmissions to fail to shift properly.
I don't know what the specific steps are for a Dodge Caravan but there should be instructions in the owners' manual. Usually it involves something like the following:
  1. Drive the car to fully warm up the transmission.
  2. With your foot on the brake, shift through each gear range manually, holding for a few seconds. Then shift back into park and remove your foot from the brake.
  3. With the engine running, open the hood and pull out the transmission fluid dipstick, wipe it clean, stick it all the way back in, and pull out again to check level.
The above steps are something like what's required on some Chevy trucks. Some vehicles require checking while the engine is off but most, I think, require a hot check while the engine is running. I could be wrong. Check your manual.
If the fluid level is OK, sniff it (don't burn your nose!) and if it smells "burnt" then it could need to be changed. Auto transmission fluid changes are usually kind of messy so you might want to have this done somewhere.
If the level is low then you need to either look up the type of fluid it needs and add some (check the manual again) or take it to a mechanic to get it topped up.
Good luck!
Getting a check for codes is a good idea too but a fluid level check is a quick no-brainer test to rule out a really simple problem first.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 11,483
