跳转到主内容
iPad Mini4 Wi-Fi版型号A1538指南 。iPad Mini3的后继版本iPad Mini4 发布于2015年9月9日。
97 个问题 查看全部
Beats Headphone Jack stuck
The headphone plug was bent a bit, when I went to put the plug in it went in swiftly and then when I pulled it out, the beats solo 3 headphone wire cord plug got stuck. I have tried everything and nothing has worked. Is there any way that I can get it out. I have the Beats solo 3 and The Ipad is the Ipad mini 6th generation. And when I go to listen to music without the headphones no sound comes out because the ipad registers it has headphones on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hi,
If a portion of the headphones are stuck in the jack you can try to delicatly remove them using this tool GripStick Headphone Plug Extraction Tool . However you need to be careful doing thiis. If you cannot remove the jack using this method then the headphonje jack would need to be replaced which is this part iPad mini 4 (Wi-Fi) Headphone Jack .
It might be worthwhile seeking out your local repair shop if you do not feel you are able to preform the repair yourself.
Kind regards
Matt
GripStick Headphone Plug Extraction Tool图片
产品
$19.99
iPad mini 4 (Wi-Fi) Headphone Jack图片
产品
$9.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Not Brendon Urie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 6
总计 204
