跳转到主内容
加入维修社区 - 创建账户
My desktop won't work
So i was about to update my Asus Desktop and, when i tried starting it afterwards it started (fans and harddrive started) but nothing worked, nothing not the mouse, keyboard screen. Is this a motherboard problem? What should I do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I've tried booting it on another screen, but still does not work.
完成的
添加一条评论
4个答案
已选择的解决方案
My problem was a 3v battery that keep the bios clock running, thanks for all answers.
这个答案有帮助吗?
得分 0
添加一条评论
Try shutting off the system by holding the power button down for about 10 sec. Once off, unplug the power from the back of the system and press the power button. You might see the fans jump as it consumes the residual energy available. Plug it back in and try to boot it.
Edit (Additional Steps to try):
Do you have another, know to be good, power supply you can try in the system?
Since it turns off after 10 seconds, that wouldn't be long enough to attempt OS boot. This sounds like a hardware issue.
Reasons for a quick power off could include:
  • Bad power supply cannot sustain required voltages
  • Short-circuit or other fault detected by motherboard power circuits
  • CPU or GPU device is seen as overheating.
Also, you might try re-seating and PCI/PCIe cards, power and data cables, etc within the system. Clean out any dust you find as you go.
这个答案有帮助吗?
得分 1
1条评论:
The fans do not move, and When i try to start it afterwards it goes for 10 seconds then shuts off. Nothing comes up to the display.
完成的
添加一条评论
最有帮助的答案
Please specify what you tried to update. Might help me and others determine the exact cause.
For now I’d suggest turning off your PC, unplugging it and opening it up. Reconnect the motherboard/cpu power cables and check if your memory is properly seated in the slots. Try to start it up again then.
这个答案有帮助吗?
得分 1
添加一条评论
Hello, it’s probably a ram issue, try different combinations using one ram, and remove your graphic card if you use one ;).
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ole Jørgen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 165
