跳转到主内容
Wi-Fi版的iPad Mini 2指南。2013年10月22号发布同年11月12号上市。iPad Mini 2就是配备了Retina显示屏的iPad Mini,在更小尺寸的的7.9寸屏幕上拥有和iPad Air相同的像素。
220 个问题 查看全部
Sunken & stiff home button.
I replaced the front glass/digitizer on my iPad Mini 2 & have had issues with the home button. It is recessed deeper in the glass compared to the original & it is much harder to actuate. I have remedied the alignment problem by forming the metal bracket for a flush fit, but the switch is still hard to actuate. I tested the button with the front glass removed from the case & it is still stiff, so It’s not anything to do with how the assembly fits in the case. It’s stiff enough that I have to be very aware when double clicking, as it will not always work. I don’t see any way to fix this as it appears that the switch spring is internal. The switch always operates , it just takes extra force to depress it. It’s not spongy or anything. Nice firm click if pressed hard enough. I would guess about twice the force of the original switch.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The button has two small plastic nubs on the back; the bracket has two small matching holes in it. Make sure the button is rotated in the proper orientation so that those two nubs seat inside the holes.
这个答案有帮助吗?
得分 0
1条评论:
I thought I responded to this already??? Anyway, the button is properly aligned. It's the dome on the switch itself that is stiff. Nothing else is involved with the mechanical movement of the button. The metal dome is just too stiff & doesn't collapse with the proper pressure. It's just stiff enough for me to have problems double clicking. More annoying than anything.
Thanks
完成的
添加一条评论
添加你的答案
kevs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 182
