My RCA 65 inch smart TV doesn't show an image anymore
Hello i have a RCA 65’’ smart LED LCD TV 1080p SL65A55-A201083. It was working fine then it would only come on after several attempts. Now there is no picture but there is a red light on the bottom. I have tried holding the power button tried the reseting the tv with the power and volume button so far nothing works. I do have voltage at the board. Can anyone help me with this problem? This is the second site i have asked this question and no help at all. wow. Thank you for your response. I have checked those things but everything looks good. Im also not sure which board is which. Could you tell me which board is the power board and were i might be able to order it and which number would i use on the board when ordering it. Thank you so much for your help.
Hi i checked both fuses and they are good. There is 5 volts coming out of the board going to the other board. Also the other board with the hdmi rca connectors on it there is also 5 volts coming in the board and 5 volts in other places on that board. The red light stays on continuously even when you press the power button. I checked the power at the power button and it has that 2 volt continuous and when you press it it goes to zero. Hope this is helpful and here are a few more pics.
2条评论
How much does a cxd4737gb cost, and have the same problem 65" Sony flat screen TV could that be the problem
由 Bobby Cruz 完成的
Hello I’m having an issue with my RCA sld65a55gq can someone help me please?? I turn the tv on and there’s no picture. The back lights come on but nothing. I can see the blank screen.
由 john tabor 完成的
