Resoldering a loose audio input jack to re-tighten connection
Hello, I have recently received an audio recorder and am having trouble trying to get it to pickup audio through it’s 1/4” jack input. I found that pushing the cord of the audio source into a particular position made audio be received, so I inspected further and I found the problem being a loose solder connection from the input jack to the board.
I am attempting to re-solder this joint but am also nervous about the ‘green paint’ that seems to come off with the loose solder as seen in the picture (leftmost pin), and how I should approach re-tightening and re-soldering the connection. Also wondering as to whether solder wick vs solder pump should be used for a board of this size.
I am new to soldering so I appreciate any help you can offer, thank you.
