Charging port not working
I have an ipad A1567 and can not find any info on it. The fire port needs replaced. How can I find it?
Another option is to have the charge port replaced by a repair shop that does micro-soldering repairs. It should be less expensive than replacing the board.
这个答案有帮助吗?
From a quick search I found that your device has its charging port soldered to the motherboard. Just look in the store for the logic board of your device instead.
这个答案有帮助吗?
yes but i do not see that ifixit sells this part :(
这个答案有帮助吗?
Yes but i do not see that ifixit sells it :(
This is the part you are probably looking for. iPad 4 Lightning Connector MAKE SURE IT IS RIGHT FOR YOUR MODEL. It should be an iPad 4th Gen Retina A1458, A1459, or A1460
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 123
