跳转到主内容
ASUS Chromebook Flip C100P was released in 2012. This was the first-ever 10-inch convertible Chromebook released. It is a laptop running Google's Chrome OS. The C100P came available with 2GB or 4GB of RAM, and silver as the only color option. Repair of this device requires screwdrivers and prying tools.
20 个问题 查看全部
Replacement screen assemblies for c100p the same as for c101p?
Replacement of the screen assembly (LCD+touchscreen glass) for the c100pa is a pretty simple procedure and is documented on YouTube and elsewhere (though, oddly, not here in iFixit). And, the c100pa screen assemblies - new and used - are readily available on eBay.
On the other hand, screen assemblies for the c101pa - an updated model that Asus issued a couple years later - are impossible to find. Does anyone know if they take the same 10.1 inch screen used by the earlier model? Maybe there are no screens for the c101p because it uses the same screen? I would sure like to hear from someone who knows before I take the plunge. Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
Hi Robert
Well, straight up answer is no
I’m sorry
这个答案有帮助吗?
得分 1
2条评论:
The screen and case look identical. If No, please detail how you arrived at an answer of ‘no’. Thx.
完成的
The C100/P has a direct connector to the screen, hardwired, not removable from the assembly. The C101P/PA have a connector that attaches to the screen.
Just compare these:
https://i.ebayimg.com/images/g/BAYAAOSwr...
and
https://i.ebayimg.com/images/g/D9kAAOSwN...
The second one is the C100P and the first one is the C101 series.
Also, why did you reply to a post that is almost three years old??
完成的
添加一条评论
for anyone wondering, YES! a c100pa screen will work in a c101p. i know horrera said no, but testing it the screen and touch work fine.
(edit: spelling)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Robert Miller 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 13
总计 461
