Won't boot past blue screen after software updates
Fixing up an old MacBook Pro (2,2) for my mom, here's what I did:
Wiped the drive clean and installed Snow Leopard on it, maxed the RAM at 3 GB and put in a new battery.
After I boot the machine and run software updates, it will not boot past the blue screen. Afterwards if I let the battery run all the way down and let it sit over night it will boot.
Here's the suggestions I've tried:
-Zapping the PRAM ect...
-Repairing the permissions and the disk itself
-Re-seating the RAM
-Putting the old RAM back in
-Safeboot, it will boot into safeboot
-fsck in single user mode
-Clean re-install of the OS
My questions would be the following:
-Has anyone seen this before?
-Is this a symptom of anything hardware specific (Drive failing, Motherboard ect...?)
-Anything I have missed?
Thanks a head of time.
UPDATE:
So replacing the drive did help in the fact that I now can get it to boot right away but only after re-setting the SMC. So I am unsure why the SMC needs to be re-set after each software update that I do, but otherwise it will not boot beyond the blue screen again. Any ideas?
3条评论
Is this the 2.16 or the 2.33 GHz machine?
由 mayer 完成的
So it turned out to be that the hard drive was failing after all, I used SMART utility to diagnosis this and an iFixit guide to swap out the drive. Thanks for everyone's help! Also of note: the Apple Hardware test did NOT catch the drive failure...
由 kellentat 完成的
Change the hdd thats it ...
由 SIMRAN 完成的
