My USB-C ports don't have Amperage, only 5.29 Volts. Nothing works.
After I plug my Macbook charger in a USB-C Hub the ports stop working well. They only can charge the Macbook but they cannot detect any other device I plug and bring only 0.05 A and the correct 5.29 Voltage. Can anyone help me? Thanks.
To be clear, the battery is not full during this charge attempt? Also, where are you taking the readings from?
由 AdminAnonymous 完成的
The Battery charges and works correctly, I'm measuring with an USB Tester. All the ports are with the same problem, now sometimes it power off alone or freeze.
由 Siegfried Stahl 完成的
