跳转到主内容
Guides and support for various television (TV) brands and styles.
9078 个问题 查看全部
Matching a replacement powerboard.
Hi,
I have a Panasonic TH-P50G10A Plasma which was struck by lightning and fried the power board. I would like to replace this myself with a cheap used powerboard out of a broken tv, and struggling to find the exact part. Is it possible to use a slightly different part? I have found a part with the same part # except for the last letter.
ETX2MM747MF K (in tv)
ETX2MM747MF E (found replacement)
My question is, can I use this part? Or how can I find what parts will work to expand my search?
Cheers.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Usually the difference would indicate a different revision of the board - something as simple as a new part vendor or minor component change.
If the seller states it is compatible with your model TV then I suggest it will work. Just make sure that all plugs/sockets/wires etc match up properly when you install it.
HIH
这个答案有帮助吗?
得分 3
1条评论:
Sounds like workable advice to me. +
完成的
添加一条评论
添加你的答案
Peter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 1,400
